I have my ps3 settings on default settings but i no longer have my red yellow white cords, just the hdmi cord. i need guidance setting it to hdmi on a blank screen
Have you used the HDMI cable with the PS3 before? it may be configured to use the AV connection. If so plug in an AV lead, then you would need to find in the settings to change the output to HDMI.
The HDMI cable may not work
Press windows key and P to switch between monitor modes
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I have the same problem! I'm using the HDMI-DVI cable that came with the monitor because it lacks an actual HDMI port. DVI is the big port with the grid, right? Anyways, is there a way to put monitor Drivers on the PS3? The monitor doesn't have a menu so I can't manually resize. Also, LittleBigPlanet automatically splits like 720p whenever I play it.
Hook up the PS3 so you can see the screen. Then go into the display settings and lower it to the lowest resolution settings. Then try connecting it again.
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck.
A DVI to HDMI cable should work, I have the same monitor, but attached to an Xbox 360, if that doesn't work then buy a HDMI Cable and a HDMI (Female) to a DVI (Male) Adapter
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
