I have a Sharp AR - M161 but it not supported to Vista to print. so if you can help to solve this problem i will happy with my work.
Thanks
Raaj
There is a vista driver available for that model as long as you are talking about the M161 not 161. Do you have the optional print kit installed or only parallel interface. If you only have the parallel connection it requires the GDI driver which can be downloaded from Sharpusa.com under support then type your model and select OS and driver type GDI
Hope this helps,
TankMurdock
