How can I do it ?
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Ok...I feel bad.. You need help so here it is.
get into SIM mode by pressing "#" key then "interupt" key then "C" key then "interupt" key again.
enter 20 then press start - enter 01 then press start.
This will clear the main maintenance counter.
This message will self destruct in 20 years....
get into SIM mode by pressing "#" key then "interrupt" key then "C" key then "interrupt" key again. enter 41 then press start - enter 01 then press start.
SHARP COPIER AR-5618S, A NEW COPIER, TONER EMPTY, I REFILLED IT, BUT TRIANGLE RED LIGHT IS BLINKING ALSO NOW, IT MEANS TONER IS EMPTY ,HOW CAN TO RESET ITS CHIP
Error L4 on sharp AR-5316E
Get into SIM mode by pressing "#" key then "interrupt" key then "C" key then "interrupt" key again.
F02 hatas? nedir ne yapmam laz?m l?tfen acil yard?m
Appear on screen U2 sharp ar 5316
Hiw to fix L4
Hello . sharp ar-5623 maintenance error light wont go off help .. replaced tonar with a new one but n good.
SOURCE: Sharp AR-5316 photocopier & printer driver
My sharp Photocopier 5316 Hang does not start .All Button show green indicator But does not work .How can solve my problem
SOURCE: Sharp AR 5316
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
SOURCE: Sharp -COPIERS - AR-5316
If you go to this web page:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
You should be able to find the driver for that machine.
Hope that helps.
Lbcoaster
SOURCE: i want to install SHARP AR 5316 WITH UBUNTU/LINUX
The software is only compatible with windows.
