Linksys Wireless-G WRT54G Router Logo
Anonymous Posted on May 11, 2013
Wag54g sip alg - Linksys Wireless-G WRT54G Router
Anonymous
Level 3:
  • Linksys Master 32,281 Answers
  • Posted on May 12, 2013
Anonymous
Linksys Master
Level 3:
Answers
32281
Questions
Helped
7905826
Points
102259
Try resetting the wireless router back to to factory defaults.
To reset the Linksys back to the default settings -
Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
M phone wont call out.. it has a constant dial tone ..can you help me?
Might be a firewall setting in your router. See if you can change the SIP ALG setting. If it is off, you need to turn it on.
Here is a site that will help you identify the SIP ALG in your router:
http://www.nextiva.com/support/how-do-i-identify-sip-alg.html.
How do you clear RNP for an HP 12C
I take it you mean a 12C Platinum.
Press f ALG. ALG is the f-shifted function of the EEX key, just above the double-size ENTER key. This will switch the 12C Platinum from RPN mode to Algebraic mode, and ALG indicator will light up instead of the RPN indicator.
To switch back to RPN, press f RPN. RPN is the f-shifted function of the CHS key just above the EEX key.
Linksys WAG54G-UK Router Blocker
Hello I have a question wirelees have a network connection at a hotspot romtelecom a router without antenna which is called LINKSYS NETWORK IS FREE WIRELEES How can I find the IP address of your router linksys As I have access to it Thanks
Is that mean D-Link DVG-G1402S router does not support VPN Server?
IT does Security • SIP Authentication with Password Encryption • Configuration Download Using HTTPS and SSL/TLS Clients Certification Encryption and Authentication • VoIP NAT Traversal (SIP/STUN) • NAT/Firewall (NAPT, TCP/UDP, DMZ, ALGs) • VPN Pass-Through • Packet Filtering by IP Address, Port Number, and Protocol
Forgot password
In case you have forgotten the password of your router, there is no way to recover it back.
ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory settings by pressing the reset button on the back side of the router. Press the button for a few seconds, the lights on the front would blink and the router would restart with factory settings. Please note that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE ALL NETWORK CONFIGURATIONS AND SETTINGS ALL OVER AGAIN
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Iam running internet cafe i have a adsl internet connection, I have bought one WAG54G wireless adsl router and 8 port Netgear switch, i have establish 7 connection through the switch connected with router...
The internet is disconnecting that means the problem is with the router. you also said that the router is getting hot.
I think probably you can try to upgrade the firmware of the router.
Or if it is a new router then try to get it replaced from the store.
Click Here for more info about the networking
2answers
Disable SIP AL
connect to the modem through telnet and type
application unbind SIP 5060 saveall
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
