Hi Briana, Just Drag & Drop the picture to the chat window of the partner, it will send. Let me know if any further issues. Hope the solution works. Regards ~SmokinJoe~
No settings to see a pic in a text. Maybe he tried to send a pic with it but His phone failed to send it. I would suggest you have someone else send a pic in a message to you and see if it works.
Sign into Skype Tap Contacts select the contact you'd like to send a file to and tap more:- send file. select the application you would like to use to find a create the file. the file will be sent as soon as the recipient accepts the transfer
try this...... go to my pic gallery, select the pic you want to send, click OPTIONS, send as picture or picture text message, then enter the phone number you want to send it to, then click SEND. hope that helps. BUt you have to have data package to send pictures from any cell phone.
Note : Sending pictures via email on iPhone has a limit of 5 pictures. With MMS you can send more than 5.
Steps for sending pictures :
Go to Photos App on your iPhone
Select Camera Roll(source folder)
Now once you see all the photos you would be able to see an Arrow pointing outwards right button on top right corner of your screen. tap it
Now select up to max of 5 pics you want to send by tapping on the pics
Once selected tap on Share button on bottom left corner you would see two options Email and MMS. Select Email(or MMS).
type the email address of person you want the send the pics to .. and hit Send button on top right corner and Voila you are done.(it might take from few seconds to couple of minutes to send the pics depending on the size you chose)
The performance of Skype is affected by the bandwidth available from your ISP. The video image your are sending and receiving occupy a large part of the information transmitted over the Internet, therefore make sure the video image setting is at a resolution of 320X240 (e-mail size) and if this is still affecting the audio quality to the other person (ie. the voice breaks up) and the video image then switch the video camera off and if sound and video image from the other party is also affecting you, then also get them to switch off their video camera.
Also check the Video and Microphone settings in Skype - Tools - Options etc. Check the correct video camera and microphone has been selected.
Normal
0
See section A. Skype in the info below to setup the Audio & Video. Also send this to your family
and friends so they have their computer setup properly. Web Camera’s have to be
setup on the program they are to be used with.Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly. A.Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
Go to Tools,
then Options, and click on Audio Settings and set the Microphone
and Speakers to the computer Audio Card.
Then
click on the Video Settings.
The
camera if Installed Properly will come up and show a video picture.
Then,
on the bottom of the page click on Save.
The camera and audio should function properly.Your friends and Family will now be able to
see and her to you. B.Yahoo Setup:
After downloading and installing Yahoo Messenger(http://www.soft32.com/download_30.html
) set it up as follows:
Go to
Messenger at the top left and click on it.
Next
go down to Preferences and click on it.
Next
Calling and Devices on the right and set the Microphone and Speakers to
Next
go to the Test Audio section and(in blue writing) click on“Open the call setup assistant” and follow the instructions on the
left window.
by bluetooth you can send pictures to the computer! for that you want to install bluetooth cd! to the computer! then pair the device! then you send pic to pc
