Tablets & eReaders Logo
Anonymous Posted on Oct 17, 2017
Wifi issue So wifi has always worked until this morning. Worked fine last night. Tablet sees wifi and says its connecting, getting ip adress etc. but then in a split second says disabled. I have turned on and off tablet a few times. Have set back to factory re-set and still wont work. Home wifi is not the issue because all other electronics connect fine.
M.B. Nataraj
Level 2:
  • Expert 97 Answers
  • Posted on Oct 17, 2017
M.B. Nataraj
Expert
Level 2:
Answers
97
Questions
Helped
14229
Points
239
When you reset the tablet your tablet wifi settings, wifi name and password will be erased. You have to detect your wifi on the tablet, connect to it and enter password right?
2 Related Answers
Anonymous
  • Posted on Jan 04, 2011
SOURCE: my galaxy tablet cannot detect
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Anonymous
  • 21 Answers
  • Posted on Mar 14, 2013
SOURCE: I'm having problems with my tablet connecting to wifi I've rebooted my router other devices work fine with it it's not reading the IP address on the router it reconize it but want connect what can I d
You might have something going on in your settings. I remember the first time I tried to connect to a network. It was a nightmare. I was pulling my hair out! You only have one device to connect. I had three devices and none of them would connect until I went in and changed my settings. I hope this was helpful. Good luck.
My proline tablet H71930i will not charge or be turned off. The indicator that the battery needs recharge when off does not show....please help it worked this morning but now it's dead.
do a hard reset and then make sure the software is up todate. 1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
How do I get my next book 8se android tablet to print
If you don't have HP Print Service Plugin and HP ePrint installed, make sure these two apps are installed. Go into ePrint and see if it 'sees' your network printer when you have WiFi on and you are logged on to the same network segment. If the apps cannot 'see' the printer in their selection menu, none of them will work until the connection issue is resolved. One other thing to try, download any app with network 'ping' function and try to ping your printer by its IP address from your tablet. If you cannot ping the printer from your tablet, you are either not on the same network segment, or there is some other connection issue.
Samsung ip adress will not connect
Set up your wifi again but closer to the router.
Can't keep internet connection
You could try and set up the network manualy from your tablet that mean's putting in the IP Address and gateway of your router into the network settings on the tablet.I have also came accross the problem of where the tablet's WiFi was faulty and needed a new one.
Your router will have a firewall setting which you can change by logging into your router through your browser and put this IP Address in 192.168.0.1 then you will need the user name and password to make any change's you might have to look up the default name and pass you can Google them or go to your service provider site.
If all this fails another option would be to change firmware or update the one your using.
2answers
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
I just got my kurio 7s last week and now the wifi wont work. the wifi turns on and its picking up my router even says it has perfect signal i hit connect then it keeps going through this 10 min ****...
If you can click on your wifi and pick "forget" do that and then restart the tablet and try again. If that doesn't work try going to settings and resetting it to factory then it will be like a new one, if you can do it without wifi some tablets wont let you past the wifi screen until you sign on.
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
1helpful
Ipad won't turn on. Worked fine last night, got down to about 5% battery left. Plugged in overnight and it won't turn on. Tried different power cables, no success. Tried plugging into PC no luck. ...
You could try a hard reset.
Hold down the power button and the home button at the same time until the device completely shuts down and the Apple logo appears.
Hope that helps!
12answers
Top Lenovo Tablets & eReaders Experts
NOEL
NOEL
Paul Bade
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
