I-Fix Appliance Repairhttps://ifixappliances.ca > samsung-oven-error-codes
Error Code, Problem, Solution ; E08, The oven is not heating, Unplug the oven to check the elements inside. The problem may be in one or most of the heating ...
Error Code: Problem
E-55: Communication error with touch panel
E-OA: Oven overheating
E-OE: Oven door lock error
JustAnswerhttps://www.justanswer.com > Appliance Repair
Jun 27, 2012 - E08 just means that there is a heating issue with your oven. It's not really specific as to which can cause the problem since there are many ... 1 answer · Top answer: yes of course. Just let me know. But what you're looking at is either a bad element (if just ...
Samsunghttps://www.samsung.com > support > TSG01001948
Since the cooktop cannot be in use when running Self Clean, this error is alerting that one or more of the cooktop burners or elements are in use. Turn all ...
Missing: e8 ‎' Must include: e8
E08 means that the motor has failed (tachiometer error). Shut down your machine and disconnect power cord for five or ten minutes. If that is not enough to clear the code call the support number listed in your owner manual.
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
