These WEB sites may help reset the security code.
RESET NOKIA SECURITY CODE
http://tjosm.com/reset-forgotten-nokia-security-code/
Nokia security code
if it does not work use nemesis service suit
http://mastercode.nokiafree.org/
SOURCE: Resetting Security Code
i have nokia 1112
my imei no is 354573018881860 i want to reset my code
357593006548708.........for this phone try resetting the phone or formatting by entring *#7870# for resetting and *#7370# for formatting in any of the case you should have your original number which is 12345 as the new code after resetting of formating but for formtting you would lose every contacts so you are advice to keep a copy of every important dorcument.
for nokia 5300 also try resetting or formatting to restore the usual pin code "12345" and to do this first copy all contacts and information need first even is restting it(which you do not lose any information) ........... to reset enter *#7870# and to formate enter *#7370# please try the first method before proceeding to the second one.
for nokia 3110c please this is your master code 6003104322
SOURCE: Forget Security Code
if u have forgot your security code, then all u need is a master code. The master code is a 10 digit number that will always be accepted as if it were your actual security code. The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Simply enter your 15 digit serial / IMEI number into the online tool (see link below). Your master code will then be calculated instantly.
http://www.unlockme.co.uk/master.php
SOURCE: forget security code nokia 2680s-2
nokia 2680s-2 RM-392 mob pe call kro to call khatm hone k bad automaticlly restart ho jata ha
