Static noise does not stop at all in one of the units how to stop it?
It is likely experiencing constant static because the walkie is in "monitor mode" constantly searching for weak signal transmissions. Press and hold the WX/MON button for two seconds to turn monitor mode off. This should fix your problem. It did for mine, which were having the same issue.
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
