Question about Whirlpool LSQ8543J
My Whirlpool LSQ8543J has started overflowing after rinse cycle
Twice now my WP LSQ8543J has filled to the point of overflowing after the final rinse cycle. Water continues to pour into the bin (and out the bottom of the machine) even once the power is cut off to the machine. The first time it eventually stopped on its own (after flooding our garage). The last time it stopped shortly after the water was turned off to the machine. (I ran several successful loads between the two incidents.)
Your washing machine has a water level sensor. There is a tube that comes up from near the bottom of the tub. The pressure in the tube increases as the water level increases. This changes the state of the water level switch to full, which is the water level control switch, the terminals of which you'll find in the control cabinet, where the timer is. There are three wires connected to the switch, a common, a low level wire, and a full wire. If that switch fails to make contact at the full terminal, no other part of the cycle will occur. That switch has likely failed. The tube point of connection to the switch could be corroded and leaking, which would also cause this failure.
Good luck.
Posted on Apr 21, 2009
  • Whirlpool Master
  • 3,361 Answers
Replace the water valve where your hoses connect to the washer.
Posted on Mar 21, 2009
6ya staff
SOURCE:
Whirlpool washer blows fuse
the pump motor is starting to seize up. It is causing the motor to work harder which causes heating of electronics causing the fuse to blow
Feb 21, 2012 | Whirlpool LSQ8543J
Hoover 700 LA keeps overflowing
Hi just read you posting.Now fortunately I have the same machine.Just a couple of questions.--1-- does the machine flood at the start of the cycle when it is filling for the wash or in the rinse cycle? 2---At anytime while it is filling does it start to wash? Now try this for me, Turn the machine on at the start of a cycle so it starts filling and then when you hear the water going into the machine turn the power off at the power point. After you turn the power off at the power point can you still hear water coming into the machine?Please reply with additional information to the questions because with those questions answered I will tell you the exact fault and guide you throe the repair.
Jun 20, 2010 | Washing Machines
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
144 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
