Question about Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GRBWW
The ice maker won't dispense cubes - only crushed.
The ice maker is making ice and I can get water from the door. When the switch is on crushed or cubed, I only get crushed.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Switch in the door is bard
Posted on Mar 31, 2009
6ya staff
SOURCE:
Frigidaire model glrs267zcwi side by side. Crushed ice comes out when either the crushed or the cubed button is depressed. How to fix it please?
It sounds like the water line to the ice maker is partially obstructed (probably semi-frozen) and the unit is making smaller than normal ice cubes. This causes the ice ejector to "shatter" the smaller cubes, producing the appearance of crushed ice.
The easiest thing to try is make sure the water line connection inside the freeezer isn't frozen. A hair dryer can be used to thaw the inlet to the ice maker, but just be careful. Remove some of the product in the compartment so you have enough room to work.
Dec 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker
there is a door in the bin that switches the cubes empty the bucket and make sure its not jammed also take the bucket out push cubes hold down the door switch not the one that turns the light off unless you unit only has one and push the switch with the door open in the back a leaver in a hole should jump up it not switch it to crushed and try it again if it still don't then the solenoid is bad or frozen
Feb 18, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
550 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
