No heat
I have a Kenmore dryer Heavy Duty, super capacity, quiet pak ..90 series, MF4002741
Model: 76904690 76904
It wont heat.. was fine last nite.. then all of a sudden ...no heat.. it still blows air but its cold..
Thank you
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
