RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Mar 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 50 inch rca tv model m50wh185 no picture but has sound
It turns on just no picture but you hear the sound just fine.
Anonymous
Level 3:
Genius:
  • Master 1,030 Answers
  • Posted on Mar 18, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1030
Questions
Helped
227755
Points
2244
Do u hear any high voltage static when you first turn on. possible high voltage problem with the high voltage splitter or focus pack. ussally when there a problem with these high voltage is being generated but not delevered to the tubes
2helpful
2answers
How much does a 50 inch RCA HDTV flat screen bulb cost
Picture and sound went out on my 50 inch tv
We were watching tv, and it was a storm. My lights went out and the tv turn off, when we turned it on again it wouldn't show picture but you could hear sound. We waited a couple of months to actually...
what caused the inital problem was a surge of energy caused by the storm. the exact problem, i don't know but it may just be that some of the power cord(including the power cord wires on the of the TV) wires have blown
MY RCA SCENIUM M50WH185 AFTER TURNING IT ON IT RUNS FOR 10 MINS THEN LOOSES PICTURE &VOLUME AND WILL NOT TURN BACK ON- GOT TO UNPLUG IT WAITE 4 A WHILE THEN PLUG IT IN AND IT WILL COME ON AT SOME TIMES...
your power supply unit is going bad you dont have much longer before it goes your volume buttons picture light. screen all run through it. go to vancebaldwinelectronics.com to replace it.
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
2helpful
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
My RCA Scenium 50in. is not turning on!!
Its sounds as if the lamp has exploded or the color wheel has. I will post a link to a site that has a trouble shooting manual on CD called RCA DLP Disc #1 which covers every DLP in the ATC line which is what your model is. They have it either in cd form or they will email it. Its a very good resource for fixing your own set.
http://servicemanuals.vstore.ca/
I have a RCA Selenium M50WH185 50" DLP Projection TV. After the TV is turned on for a few minutes (10 or so), I hear a very high-pitched buzzing noise. It is so unbearable, that I'd rather not watch...
If its a projection set it may cost more to fix than its worth, only thing I could suggust is to pull the back off it and try to figure where this sound is coming from and possibly replace that board.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
