This facility worked perfectly. Then all PC towers were stolen and I have replaced the towers and have managed to sort out the printing from the computers but cannot do any scan to PCs. I am met with a message that reads " Cannot find destination PC, check the PC." Can someone help me to sort this out please?
SOURCE: kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
SOURCE: KM-2530 with C0050 error code ?
it's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
SOURCE: SYSTEM ERROR
The Kyocera MK 3050 shows system error. We have turned it off and back on this does not help.
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
I called the IT guy and he has sorted it out.
