You'll need to get that looked at. I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: need an owner manual for mcculloch eager ****** 300s-16
You would pay the manual about the price of new saw. These are made in china and usually motor or the switch blows. Check that the voltage pass thru the switch and if so and it dont work, throw it away.
Testimonial: "not what I was asking about. I wanted a user manual for mcculloch eager ****** 300s-16 electric chain saw. You people can't read."
SOURCE: I have a McCulloch chain saw- pro mac - 610- the
This saw? Be kind to your elders.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/564ff25e56449e8c88256c2f001cd723?OpenDocument
The IPLs I’ve found for your saw don't show this detail. I suggest you try here:
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9 (free to join)
There is a McCulloch thread. Your saw is held in high regard. I’m quite sure some of the members will be willing to post some close up photos of the set up on their saws. HTH
Lou
SOURCE: mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
Warm:
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
SOURCE: chain comes off mcculloch electramac em250 chain saw
Adjust the chain until you can pull on it and it will come away from the bar but will not hang from the bar. If that does not solve your problem then the chain or drive gear is worn out. If the oiler is not working it is for sure worn out.
SOURCE: McCulloch 14" chain saw Model CS 38 EM It quit
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Testimonial: "I checked as you suggested and I removed the pump from the crank shaft and the plastic gear is stripped. Now I can not find a pump. Thanks Jim"
