Check the Video settings, ensure that resolution on Sat box settings is the maximum supported by your TV.
If there is frequency setting, ensure it is set up the same as TV.
Check also PAL-Secam settings, depending on your zone.
OTA - Over the Air Software Updates will be broadcast via satellite for the product when new updates are
available. Humax reserves the right for deciding when the software updates will be released.
Follow below to ensure that you receive the OTA Software Updates when they are released:
1* You are connected to a suitable satellite dish and are receiving the all of the freesat service.
2* The signal strength and quality are at a high level; if you are experiencing problems with the signal
then please do not continue with the download.
3* The product is in Standby mode each night allowing it to detect, download, and install the updates
when broadcast
Caution:
* Please do not unplug the product from the mains during the software update procedure; this can
cause the product not to operate.
* Please do not remove the antenna cable from the dish from the product during the update as this can
Note:
* For information on the release of new software or the changes made please visit www.humaxdigital.
com/freesat.
* The download can take between 5 - 10 minutes to complete.
* During the update process you will not be able to use the product.
* During the software update scheduled recordings will not take place.
* You cannot schedule programmes during software update
OK.
The HDMI/DVI cable is OK. I've managed to get a
HD signal using an HDMI/components converter box, but the resulting picture is not as good as Freeview!
The problem remains - no signal via HDMI/DVI input. Could it be something to do with HDCP?
