I need to unlock my NEC TV-27W from being locked in Hotel Mode. I have lost the original remote controller and only uses a universal one. Any help will be gretaly appreciated.
You must have to enter its service mode option to release the TV from Hotel mode. It will be difficult to enter the service mode, with a universal remote control. Any way, just try to enter into service mode. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. More than Nine and half Lakh viewers cannot be wrong.
SOURCE: Toshiba CF32H50-no control from remote
Could be the remote does not operate on the correct frequency, but also may be the IR reciever sensor inside the TV, best bet is to bring your remote to a pawn shop and try it on a set there (they sell older model sets look till you find one like yours). once you determine the remote is OK, check the IR sensor for bad solder connection or replace it by soldering a new one in. Also some Toshibas develop micro CPU issue (the computer IC), another thing you can try is cleaning the main board control area with electrical cleaner residue can load down the control circuits but then the buttons would also malfunction.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press
4725 (menu service appears), then search HTLSRC (position 090), then
set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is
deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
SOURCE: I HAVE A J25420 TV WHICH I BOUGHT FROM A HOTEL AND
Pretty much. This nice thing about RCA stuff, more than any other brand, is that the universal remotes they sell will run their equipment without (most of the time) the need to try additional RCA codes. I know this from personal experience.
SOURCE: I have a TruFlat RCA
Try this -
Regards,
Tony
SOURCE: my model is 32HF7945D/27
YOU HAVE TO BUY A MASTER REMOTE FROM REMOTES .COM TO BE ABLE TO GET INTO THE SET UP MODE. IT WAS 55.00 ALSO YOU WANT TO GO ON LINE AND DOWN LOAD THE MANUAL IT IS 45 PAGES LONG AND NOT EASY TO UNDERSTAND. SO I CALLED THE HELP NUMBER AND THEY HELPED ALOT GOOD LUCK
