The washing machine won't spin. It stops sometime after the wash cycle and then beeps. The spin cycle seems to start and stop over and over again. It's almost like the belt is slipping.
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Hi just read your posting.Now you said in your posting it does not drain before the spin cycle, but does it drain before the rinse cycle?Does your machine stop and beep and show an error code in your LCD display or if you have the other model a series of lights?Have you tried advancing the cycle to spin and pushing the start button?Please reply with additional information and I can help you track down this fault.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
