2002 Ford Crown Victoria Logo
Justin Harris Posted on May 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Poor radio reception
I am getting poor radio reception
Steve
Level 3:
  • Master 696 Answers
  • Posted on Apr 24, 2015
Steve
Master
Level 3:
Answers
696
Questions
Helped
239400
Points
55809
Hi
The usual culprit here is a poor ground at your radio antenna. The antenna is located in a pretty hostile environment due to salt, dirt etc.
A good spraying of silicone spray (safe for plastics) on the underside of the antenna mount and a careful tightening should improve your reception.
Hope this is helpful.
-Steve
  • JAYMZWAY Apr 24, 2015
    Sounds as if it makes sense to me. I second this opinion as a try this first solution. Then all else fails try my solution. Cheers bro..
JAYMZWAY
Level 1:
Habit-Forming:
New Friend:
  • Contributor 5 Answers
  • Posted on May 18, 2013
JAYMZWAY
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
5
Questions
0
Helped
4553
Points
17
Check your antenna wire to see if it came unplugged from back of radio
    If only time you have poor reception is when you turn other things on in the car. This is called interference. There is nothing you can do about it. Other than to turn off the other component that is causing the interference. or Try getting an aftermarket antenna and relocating the antenna further away from what is causing the interferences.
Antenna removal
Poor reception is ant. No reception is radio. Poor explanation gets poor answer
Poor radio reception and Setina push bar installation question
for the poor reception have you plugged in the antenna wire into the radio
Radio reception is poor
Have you or someone pulled out the radio in your vehicle recently it could possibly be the antenna plug isn't pushed back in all the way?
1helpful
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
2answers
Poor radio reception 04 Jetta
It may be more of a design flaw oppose to a actual problem. However, you can purchase signal booster that simply plug between the radio and the cars antenna.
Chk. for a poor connection wear entenna plugs into radio, it could have corrosion or it could just be loose.
could be or the station you have on.in between towers you will get static.
3helpful
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
No am reception and poor fm reception - 2004 Kia Sedona
If the antenna is on the front, pop the hood, and locate where the antenna wire connects to the bottom of the antenna and make sure it is connected well. If everything checks out there, you will have to pull the radio from the dash, and look at the back of it. There will be a large black wire by itself connected to the radio. Push it in to make sure its connected as well. That could really be your only problem unless your radio happens to have a fault on the inside which is extremely rare. Hope that helps
Factory radio reception failing
I would suggest installing what is called a filter capacitor.You can get these at most car audio shops or a electrolytic capacitor rated at 16v or higher and around 30uf (the capacity is not very important) you connect it from the Positive to the Negative on the radio. The idea being a capacitor will allow the A/C current (noise) to pass through to ground without going into the radio and this is usually the cause of poor reception.
Another possible cause could be simple a poor quality antenna, some manufacturers are going cheap on the antennas since most people don't listen to the radio anymore. You could try to screw an antenna off of a different car onto the base on this one and see if that clears up the problem, they are a some-what universal thread.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
