SOURCE: Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
SOURCE: HELP!!! Help wiring new motor for CKL60-1
Thank You
SOURCE: Ourside AC unit fan runs backwards after repair
call them back the tech should have seen the fan was running backwards talk to the owner. an electrical surge can hurt the motor, don't be surprised if this is the case. Charges are in range. We are professional mechanics.
SOURCE: Easy Start Capacitor
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
SOURCE: I have to replace the
All the terminals are connected together so it won't matter which terminal you use, just as long as you have the Herm, Com, and Fan wires correct. Hope this helps!
