Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Uniden scanner hi i just bought a uniden ubc92xlt.and i dont hae a clue how 2 use it can any 1 help me pleas??
    Sergeant:
  • 76 Answers
The Service providers of Bigpond services are always offering specialized technical support for the users and businesses. As Bigpond has made opportunities and bought excellent services for the easy to use of each person.
BIGPOND EMAIL COMMON TECHNICAL ERRORS ARE -
· User might be stuck in some password regarding the issue in Bigpond Email Account
· Your account has been hacked or blocked due to some technical problem
· Even after proper connection, your Bigpond email is not working properly
Our expert technician is there for all Bigpond email users any time anywhere. We are available 24*7 in 365 days for resolving all Bigpond email associated Problems. For further information Dial Bigpond Technical Support Phone Number: - 1-800-383-368
Posted on Oct 12, 2018
    President:
  • 2,761 Answers
The 92 is a fairly straightforward unit, but before you can program it you need to know what frequencies are active in your area. For a comprehensive database of active frequencies, by area, visit
www.radioReference.com
You can also Google search fort your area frequencies.
To program a known frequency into the scanner:
1. Press Hold. Then enter the channel number
where you want to store a frequency, then press
Func and Pgm. The channel number appears.
2. Use the number keys and to enter the
frequency (including the decimal point) you want
to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2,
Error appears and the scanner beeps three
times. Enter a valid frequency.
• The scanner automatically rounds the entered
number to the nearest valid frequency.
For example, if you enter 151.473 (MHz), your
scanner accepts it as 151.475.
The manual contains much more useful information, and I suggest that you read it cover to cover. In case you need it, here is a link to the manual for the BC92XL, the USA version of your scanner:
http://www.uniden.com/pdf/BC92XLTom.pdf
Posted on Jan 02, 2010
    Champion:
  • 279 Answers
Go to uniden.com and look in customer service/manuals. They have it to download
Posted on Sep 19, 2009
Http://phone.manualsonline.com/search.html?q=uniden+ubc92xlt+scanner&submit.x=42&submit.y=16 Go to this site and download the manual and then go to www.scanning (what area ,state,city,country your in) .com and you should be right where you need to be load the numbers in and you have it. or contact me keith7469@bigpond.com cheers :-)
Posted on Jun 13, 2009
6ya staff
SOURCE:
What type of ariel do i need for uniden ubc92xlt scanner
Are you looking to replace the antenna on the unit or hook it up to a larger separate antenna?
The antenna connector should be a standard BNC, there are a range of antennas to choose from either way.
Dec 31, 2016 | Uniden BC92XLT Handheld Scanner
Uniden ubc92xlt
Remove the battery for a hour. Put the battery back in. Press down at the same time and hold the #2 and #9 key when you switch it on - that will do a factory reset on almost all Uniden scanners. Then release, push manual, program, enter frequency of the local weather station and you should hear it.
May 05, 2014 | Uniden Radio Communications
My uniden trax 5000 gps says insert sd card, i dont know what to do
I have a UNIDEN TRAX5000 it has all of a sudden started coming up with a message "Please Insert SD Card" we have never had a SD Card in our GPS before and it worked perfecly... Pleas HELP!!!
Jun 06, 2011 | GPS
Hi im new to scanning i bought a uniden ubc92xlt handheld scanner bit dont no how to scan propley anyone can give me any tips how to use this for police taxies planes regards paul
Programming and operating the UBC92XLT is fairly straightforward, and detailed instructions can be found in the factory manual. If you don't already have this document, you can download and print it here:
The above manual is for the USA model BC92XLT, but the two scanners are nearly identical.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Listening in since the 60's
Sep 11, 2010 | Radio Shack Radio Communications
Uniden ubc92xlt cant get any sound
Connect a set of headphones or a small ear plug in the jack on top of the scanner turn volume up, squelch open, then see if you have sound, if so replace the internal speaker. hope this was helpful...
May 31, 2010 | Radio Communications
User manual for uniden bearcat ubc92xlt
Thank you for your questions.
Please find the user manual for the Uniden scanner here (it may take a few moments to load). It requires a PDF reader to view the document such as Adobe Reader or Foxit Reader.
Best regards.
Jun 30, 2009 | Uniden Boating
Can't put codes into scanner
The 92xlt manual can be downloaded from here http://www.uniden.com.au/RESOURCES_MAIN/pdfs/UBC92XLT_for_web.pdf
Hope this help.
JimmyT
Feb 04, 2009 | Uniden BC92XLT Handheld Scanner
Uniden UBC92xlt
foursons, have you tried resetting the scanner yet. On pg 47 it mentions about turning banks of channels on or off. Possibly some banks got turned off. Resetting the scanner starts on Page 53.
I hope this helps somehow, and good luck with it,, Mechanic
Feb 11, 2008 | Uniden BC92XLT Handheld Scanner
I dont know how to progam it
Link: http://uniden.com/pdf/BC350Com.pdf
This link is the owners manual with step by step instructions.
Note: Pleas vote for me.
Jan 27, 2008 | Uniden BC350C Base Scanner
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
274 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
