Toshiba 37HL67 37 in. LCD HDTV Logo
A
Anonymous Posted on May 18, 2013
Black circles on screen - Toshiba 37HL67 37 in. LCD HDTV
There is a round black circle, bottom right corner of the screen when on
could be a burn from constant display of each channels ID
turn off from the wall
wait an hour
see if the screen settles
2answers
Why is there two black spots in image on screen. Two round black circles. Not sure what it means and where they came from
1st make sure screen is clean. inspect when off. use only cloth slightly damp with water.
2nd make sure it is not the image by looking at another image or a blank white screen. Some test images will display each color.
if it is there on any image the pixels are dead. But being circles sounds more line screen cleaning
Black spot screen
What sort of black circles? Are they dead pixels I wonder?
Large Black Pixellated circle on SL600 camera
LCD screen is damaged - repair probably very expensive.
2helpful
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Black circles on left edge of lcd tv screen
Bad LCD panel. https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=7857212
I think the inside panel is cracked
Yes lcd screen is cracked. No way to repair, other than changing screen. Cheaper to buy new tv.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
