Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Posted on Dec 24, 2017
Panasonic PT53TW53G-Picture is wavy and almost doubled
The picture is still there, but not very clear. Previous to the picture being distorted I've used the split picture option quite a bit. I wonder if that has anything to do with that. Please let me know, if I can fix this myself by buying a part or if I should call in a professional.
Thank you,
5 Related Answers
Anonymous
  • 934 Answers
  • Posted on Dec 11, 2007
SOURCE: Panasonic PT-53TW53G
Mikey,
There are any number of possible failures that can cause the symptoms you're describing. For example, C509 a .47uf/250v mylar cap has been known to fail in those units causing the wavy lines. On the other hand convergence amp failures can do the same thing. That unit uses two STK392-110 Sanyo amps at pos# Ic7001,Ic7002 Panasonic p/n# C5aa00000203 and more in that circuit needs to be tested and signal traced to isolate all of the problem if the amps are the culprit. In short, I don't think this is one you want to tackle with less than a 20 mhz scope and some serious background in electronics.
Bill
Anonymous
  • 4 Answers
  • Posted on Aug 03, 2008
SOURCE: distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 08, 2008
SOURCE: tv is a little distorted
need the model number of your set it sounds like the convergence ICs need replacing. Please reply to this same post with your model number and I will post the correct ICs for your model.
Anonymous
  • 87 Answers
  • Posted on Apr 12, 2009
SOURCE: double images
Convergence amps bad call a tech make sure he does'nt use generic parts A Toshiba service center should know what to do around 300.00
Anonymous
  • 3459 Answers
  • Posted on May 14, 2009
SOURCE: Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Showing double and red
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Wavy picture when first turned on and then shuts off within 30sec.unplug 2-3 times and then picture clears and stays on until turned off.Then repeats same problems when turned back on.
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Picture is wavy and double vision
*Screen Looks 3-D
*Colors wont align
My bottom part of tv to the left side became a little wavy and it's showing double and you can see also letteing in red color.
*Screen Looks 3-D
*Colors wont align
1helpful
Picture and lettering are double and wavy
the DPTV305 - DPTV345 convergence repair kit at the following link should repair that issue. The kit includes the replacement parts and a CD with detailed repair instructions.
http://www.tvrepairworld.com/
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
*Screen Looks 3-D
*Colors wont align
2helpful
Double picture
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
TV turns on and then, after a few seconds, picture changes to "double vision".
*Screen Looks 3-D
*Colors wont align
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
