My washer dryer will not dry clothes, i am assuming the water is hot to wash the clothes as it reaches the end of the cycle fine (am told if water was not heating it would not rinse or finish cycle)am unsure of whether there is a reset button inside machine or how to clean out a filter, any help would be much appreciated
Hi the inlet tube that takes the water and the soap poweder to the washing machine drum is blocked, and causes the water and powder to overflow and leak from the powder draw? any advise? or any suggestions where I can find a service manual for my hoover six express 1300 (WDM 130) ?
on a 6 year old WDM130 - some rather bizarre things happen. It will go through the full wash cycle with no problems- sometimes. At other times it reaches the end of the cycle but hasn't rinsed properly or spun, so washing v.wet and not clean. But I can get by this by...
pushing the on-off button on the front on and off about 8 times halfway through the wash cycle. This seems to get the cycle back on track again and it will complete. Also, if it dosesnt spin, I can re-set the proagramme dial to the spin setting, and start the machine with the door OPEN - and it starts! But it won't do this at the start of the programme.
What have I done? - looked at it, cleaned out all the pipes, hoses to make sure not blocked. And looked at a new machine. Problem is I'm tight, and also this machine was under an extended warranty and had a new door, drum, motor, programmer, timer, relay, tray, etc. over the course of the 5 year period. And its performance (when it does a full cycle) is excellent - still. Is there any way of unpicking what is wrong with it, or is it a service engineer call out? Also, I'm intrigued. How can switching it on and off lots of times make a difference, but it does?
