Im trying to make sure I get the remote for the amp hooked up right and I dont know what to hook the orange wire up to coming out of the back of the stereo
You need to connect the Power wire (Most likely red wire with fuse) to the battery and run it to where you put the amp. You need to also drill a whole in the car and make sure it is grinded up and bare metal is shown. Screw the ground wire there with a bolt and nut. You will then need to run the rca cables from the amp location to either the back of the headunit if it has RCA outputs, or use a Line out converter, you can get them at best buy. Then you need to find your cars wiring harness code and figure out which is the remote ignition turn on and tap into that and feed that wire back to the amp to turn it on. Hook all wires up and make sure power and ground DO NOT TOUCH.
If you are running your speakers/subs from an external amp, then you wouldn't use any of the wires in the back. Usually you don't have any type of menu to change to make anything work. Some units have the ability to turn the signal off to the amp. What color are the wires in the back that you have remaining?
i don't know exactly what system you are using
from what you stated your saying the monitor is powering up when put car into reverse
but the camera is not coming on
what this tells me is either the camera it self not getting power or ground
u hooked up the video wire between monitor
the camera needs to get power some how it might be the wire that hooks into monitor but i don't think so usually that just the video wire (but depends on system)
i assuming there is one or two more wires on the camera itself that needs hooked up
a power wire
and a ground wire if there no ground wire then frame where camera is mounted to on car needs to be cleaned of all rust and paint
I assumed allot if this don't help you at all please let me Make and Model # of your camera system and i try and help you more
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Once I had this problem and had to strip the wires under the seat and hook them up to another power source ((Your Battery)) Find the wire that moves the seat back and strip the wire, then hook it up to a seperate wire leading to the battery ((I used jumper cables)) If successful the seat will move back and you'll be able to remove your seat.
they are your speeker wires. the best the to do is to hook up the colors that are the same color to the color wires on the back of the radio. dont hook them all up at once two colors at a time.by doing this it will let you know what speaker you have hooked up.
Check your neutral switch, its usually on drivers side on the back of stearing column .Its easy to reach and if you consult a mechanics service book, it will be alot easier to find and save you alot of frustration. Please rate this. Thanx.
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is on...you will blow amp
