will be some sort of error code, depending on number or timing of flashes will relate to different fault codes. search fault codes or manual for your TV to find out whats wrong with it or take to repair shop.
could be HT lead , coil ,plug, mechanical fault Burnt/bent valve/loose insert) injector fault /blocked, wiring. Run the fault codes for a list of possible reasons for misfiring
Fault code pointing to the area of the charcoal cannister and associated evap plumbing. The code generally just gives you a pointer it doesnt often tell you exactly whats wrong.
check fuel pressure could have restricted fuel filter engine could be out of time.timing chain slipped time.but first try code scan look for fault codes.
for best result, have it on a fault diagnostic machine, which will generate a fault code of whats wrong. saves paying out for things that are not at fault. hope this helps and if you need any more info just ask
Yea I get where your coming from, they give you general idea of whats wrong, or an in accurate list. Your going to have to have the codes extracted from the computer by a shop mechanic that can pin point whats wrong. The computer will hide the codes, thats where dodge gets their money. Hope this helps.
-Steve
Sorry buy you have the green screen of death, sometimes this fault also appears with with a red section in the player 4 LED, as well as as an error code (e74). Check to see if your xbox is under warranty and microsoft should be able help. Good Luck.
