When i turn on my tv, the blue light blinks a couple of times than the little red light just starts flashing and doesnt turn on. what is wrong with my tv?
Tv not turning on when i turn on my tv, the blue light blinks a couple of times than the little red light just starts flashing and doesnt turn on. what is wrong with my tv?
It could be a number of things ranging from a faulty power supply, bad connection, or damaged circuit/components. It would be best to have a qualified technician inspect your TV and determine the exact cause of the issue.
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Your lamp needs to be replaced. I have the same issue. My tv warned me a few months ago that the lamp was in need of replacement.Your lamp needs to be replaced. I have the same issue. My tv warned me a few months ago that the lamp was in need of replacement.
You can't post conmments that contain an email address.
The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
