Ive connected my m/board but not sure where my hdd led lead and power led go on system board
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
You can download all the info for this board from the following link: http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ClassValue=Motherboard&ProductID=2361&ProductName=GA-965G-DS3 The front panel & power connectors are just below the IDE connector (see diagram). Connect the power LED on the 3 pin header lust to the left of the front panel headers. Connect the HDD LED to pins 1 & 3 of the header. Please update the question & let us know if the information given was useful to you - Good Luck!
