Help. I can't release the carseat from the easy base 2. I suspect alignment wasn't right when I fitted the car seat onto base. But can't get base to release as I think seat belt got caught somehow. What can I do?
SOURCE: Have purchased Maxi Cosi baby restraint with Easy Base - Iso fix,
The Maxi Cosi CabrioFix and EasyFix can only be used with IsoFix or the seat belt on (preferrably) the back seat. Please don't alter the mounting system of the seat as it will give unpredicable results!
The Commodore name has been around since 1978 so it is possible when you own an older Commodore you won't have any means to fix the Maxi Cosi seat.
If you do have IsoFix and/or seat belts in the back seat then please elaborate on the exact nature of the problem.
With kind regards,
Babycare.nl
Erwin de Raad
SOURCE: fixing maxicosi seat to base
If you have a Cabrio Fix carseat, underneath the carseat should be two silver metal bars that slot into the base, if these are not on the carseat then you have the Cabrio model which is not compatible with the base.
I hope this helps.
SOURCE: hi i bought a maxi cosi cabrio fix car seat and it
hi
NO THIS IS A CABRIO CARSEAT NOT A CABRIOFIX SEAT SO IT WONT FIRT ON THE BASE ONLY FIT THE CAR WITH A SEAT BELT
SOURCE: I took the carseat cover
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then choose the model carseat you have so that you can download a replacement manual.
If you can't find the product you have, use the "Contact Us" tab to get in touch with the customer service department for your area.
SOURCE: Hi, I would like to ask
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
