Question about Canon Rebel XT / EOS 350D Digital Camera
Why do I get Error 99 in my Canon EOS 350 D?
I have been experiencing sporatic error 99 messages for the past 1 week with my kit lens and my Canon EF-S, 18-55 mm, 1:3.5 - 5.6 II. This original Lens was bought along with the Camera. I have taken just over 10,000 exposures with my camera in 16 months. If I change the lens, the camera works fine. I have done this, but still the error continues : 1. Carefully clean the 8 gold color lens contact pins on the camera body lens mount with a pencil eraser. Do this while holding the camera so that any eraser dust will not fall into the camera. 2. Take out both batteries. Also remove the CF memory card. 3. With the batteries removed, turn the camera switch on for 3-5 minutes. He said that this clears the memory. 4. Turn the camera off and put the batteries and CF card back in. 5. Re-attach the lens and turn it back on.
  • 12 more comments
  • Anonymous Nov 21, 2007
    when i take any shot by camira show these word (error 99)
  • Anonymous Nov 25, 2007
    Hi I am Anand,
    I a professional photographer I had the error 99 problem in my Canon EOS 350D with sigma lens 17-35mm while shooting a landscape picture which was very important to me and suddenly i had this problem and i did not know what do. I shut down may camera and after few hours i switched on the camera it was working fine Should i give may camera for service? and get it checked.
  • Anonymous Jun 10, 2008
    My camera has the same problem. How I fix that?
  • Anonymous Aug 25, 2008
    i was taking pics from my EOS 350 D then all of suden this mesage appears on the screen camra stoped working plz help me out
  • Anonymous Oct 13, 2008
    hi i have this problem! what can i do about it?
  • suckygrrr Oct 15, 2008
    I have the same problem, but I JUST got my camera. So there should be nothing wrong with it. However, when I look in the CF card holder, one of the copper things is going through the middle a bit, I dont think its supposed to be like that, is it?
  • Anonymous Nov 01, 2008
    I have a Canon XT
    sometimes appears Error 99 I turn it off and on, and keep shooting.
    I would like to repair it, and know what is it ?
  • chr1stoph3r Nov 17, 2008
    auto focus not focusing and when using manual focus err 99 comes up . I have tried the solution for err 99 but dosn't solve it .
    Thanks chris
  • Anonymous Dec 04, 2008
    My camera also shows error messages when wanting to take a picture and when the message appears, it doesn't take the picture.
    It acts like it takes the picture, but the picture is not there
    But I will take this tip and clean the lens.
  • rickhugh Dec 14, 2008
    Is a error 99 a shutter problem or lens contact problem?
  • rwbrooks60 Dec 23, 2008
    I have same problem and tried this soluntion but still getting error 99 and camera will not take photo. Camera is only a few months old so should not be having this problem.
  • Anonymous Mar 26, 2009
    ERR 99
    CANON EOS 350D        ERR 99
  • Corrado Baldini
    Corrado Baldini Mar 29, 2015
    Canon 330D EFS 18-55 + TAMRON 55-200 -both lenses got error 99. Just followed procedure above suggested and fixed brilliantly the issue! Thanx so much indeed. Corrado (Milan Italy)
    Sniper:
  • 51 Answers
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
  • 2 more comments
  • karmen_ioana
    karmen_ioana Feb 25, 2013
    Jarrett, I tried doing this. After the first step which goes well(1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture.) when I turn it on after inserting the cf, it says again error CF, whithout even trying to format it or anything. Should I try format it using a card reader or replace the cf?I mention that is the same cf I bought it with so there can't be any compatibility issue.Thanks!
  • karmen_ioana
    Jarrett, I followed the steps you said. But after the first one(1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture.) when I turn on the camera after I put in the cf, it says on the display error cf, so I can't go on with formatting or anything else. I mention is the same card I used before with no problems, so there's not a compatibility issue. Should I format the card with a card reader or should I just replace it? It's the card my problem or the camera?Thanks!
  • Corrado Baldini
    Canon 330D EFS 18-55 + TAMRON 55-200 -both lenses got error 99. Just followed procedure above suggested and fixed brilliantly the issue! Thanx so much indeed Jarrett. Corrado (Milan Italy)
  • Corrado Baldini
    I am sorry: Canon 300D not 330D
I am desperate; I am at Normandy (France) to see the D-Day sites...something I've waited to do for 40 years. Accidentally, my Canon 350D fell on the ground; I picked it up and it worked fine as I took dozens of picture in Paris...but now that I'm here, absolutely nothing will turn on, even though it downloaded picture to my laptop just this morning. Please help; what can I do?
FYI, after the accident, the Error 99 message came on...but then went away; is there a link here?
Posted on May 03, 2008
Solution #6 is what exactly Canon emailed me few minutes ago and is not the solution, in my case.. I still get err 99.Maybe a different memory brand. Never buy Canon. The "International Warranty" is not really international....just for the USA and maybe Canada.
Posted on Aug 13, 2009
    New Friend:
In my case, when using an old EF 35-80 lens, using manual focus completely cured the problem. Therefore my deduction is that The EOS350D has not sufficient power to drive the focusing motor of a lens where the friction has increased a bit, whatever the reason (dirt, dried grease in lens mechanism, wear, etc...
Posted on Oct 29, 2009
    New Friend:
In my situation -EOS 350D with stock 18-55 lens- it ONLY happens while towards the wide angle limit -around focal 18mm- If I zoom past 24mm right on the dot mark next to the 24mm, it NEVER happens. So I make sure that I am a bit past 24mm with the focal and I shoot with no problem whatsoever.
Posted on Nov 26, 2012
    New Friend:
  • 28 Answers
According to question, it should be related with power diaphragm unit in side of lens. For more specific the canon bundle lens product has manufacture defective. The wrong design and material causes braking itself of control flexible printed circuitry attached with power diaphragm. And the err 99 code shows up. But canon wont say it is wrong designing. Repairing the problem is not that expensive fortunately. It usually cost around $35 to $85 on the repair market. It is delicate job so I won't recommend doing user by oneself unless the owner is very skillful to repair in electronic and mechanic! Of course if you think no matter with destroying the lens at the end.
Hope You Luck! A Professional Camera Clinic Guy!
Posted on Apr 02, 2015
  • 42 Answers
The aperture diaphragm of the Kit-Lens may be "damaged" by unkown reason(s), such that it cannot stop down. Prove it when you try the depth-of-field button several times, the stopping-down action may fail sometime. Therefore, I have to bought another second-handed one to solve this problem!
Posted on Aug 24, 2007
    New Friend:
    Problem Solver:
  • 9 Answers
Posted on Apr 06, 2014
6ya staff
SOURCE:
How do i fix error 99 on my camera
Error 99 is Canon's catchall error, basically meaning "none of the above." The most common cause is miscommunication between the lens and the camera body. Take the lens off the camera and clean the electrical contacts, both on the back of the lens and in the mount on the body. Try a different lens if one is available.
Mar 01, 2012 | Canon EOS 3000 Kit 35mm SLR Camera
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
Error 99 on screen cant take picture intermitant
Error 99 is known as Abnormal Mirror operation. Follow the link for help;EOS-1D Mark III/EOS-1Ds Mark III: AF Accuracy Adjustment
EOS-1D Mark III/EOS-1Ds Mark III: Abnormal Mirror Operation (Err 99)
It should be noted that the AF accuracy adjustment advisory is in addition to the previous EOS-1D Mark III AF mirror adjustment service notice. Free repairs are being offered for customers affected by the "Err 99" mirror problem, and Canon is also providing free AF accuracy checks and adjustments for customers experiencing problems with soft focus when using any but the central AF point.
Finally, Canon Japan has published a new manual entitled "EOS-1D Mark III AI Servo Auto Focus Manual" aimed at helping owners understand and get the most from their AF system.
Jan 01, 2010 | Canon Cameras
What is error 99
What wide angle lens is it need f number it may be to old to work on eos 400d
Dec 27, 2009 | Canon EOS 400D Digital Camera
Error 99 on EOS Canon 450D
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Dec 04, 2009 | Canon EOS 450D Digital Camera
I have a Canon EOS, 1000D which I purchased in Feb 09. I have an error message coming up on the screen everytime I take a shot (which doesn't record). The error is a Err 99, "Shooting is not possible. Turn...
I did some digging and found that this error is most often a lens communication error. Are you, by chance using a non-Canon lens?
Try the following:
1. Remove the lens and take a picture without any lens on. If you get an ERR 99, then it is a camera issue and you will need to contact Canon for further troubleshooting or repair (ie. not the lens).
2. If you do not get the error with the lens off, try it with a Canon lens or any other lens. If no error, it is a problem with the original lens.
3. If the error occurs on both lenses, clean the lens contacts both on the lens and the camera (refer to your manual).
Hope this helps.
-Tor
Nov 21, 2009 | Canon Rebel XS / Eos 1000D Digital Camera...
Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
Aug 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon 1000D
I have the same problem with my 1 month old EOS 1000D.
I tried cleaning the lens contacts, but the problem was not solved.
ERR 99 is a generic error. I think this is a common message for a lot of malfunctions.
Try the following steps.
1. Remove the lens and try some clicks.
If you still have the problem then it may not be the fault with lens or contacts.<go for step -2>
If u still have, you have to get it repaired by professionals.
2. Remove the memmory card and try some clicks..(without Card)
Hopefuly u will find it working...
Format your Memmory card & reinstate.
For me the 2nd option worked...(for now !!)
Aug 22, 2008 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XT / EOS 350D Digital Camera Logo
28,112 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
