There is a flash memory card slot in the Kodak EasyShare CD40 Digital Camera. I have used a SD Card before, but have misplaced the SD Card.
Now I have no information as to what types of SD Cards I can use.There is a flash memory card slot in the Kodak EasyShare CD40 Digital Camera. I have used a SD Card before, but have misplaced the SD Card.
Re: Cannot locate info. on what SD Cards I can use in my...
According to the specifications, there is no flash memory card slot in this model. The only way to transfer pictures is via serial cable to your computer.
Sorry, I miss typed the model number as DC40 (totally different camera) instead of EasyShare DC40...the SD (Secure Digital) protcol memory cards are available up to 4 gb capacity. (You can NOT use the newer SDHC (Secure Digital High Capacity) format cards in your camera) For the sake of compatibility I would recommend a 512mb or 1gb SD card. For a 4mp camera I would get a 50X (speed) or faster SD card. There are numerous good sales in this range due to the adoption of the backwards compatible faster and higher capacity SDHC protocol. The older MMC (MultiMedia Card) protocol cards are generally less capacity, slower and not worth the few dollars you may save. Sorry, I miss typed the model number as DC40 (totally different camera) instead of EasyShare DC40...the SD (Secure Digital) protcol memory cards are available up to 4 gb capacity. (You can NOT use the newer SDHC (Secure Digital High Capacity) format cards in your camera) For the sake of compatibility I would recommend a 512mb or 1gb SD card. For a 4mp camera I would get a 50X (speed) or faster SD card. There are numerous good sales in this range due to the adoption of the backwards compatible faster and higher capacity SDHC protocol. The older MMC (MultiMedia Card) protocol cards are generally less capacity, slower and not worth the few dollars you may save.
You can't post conmments that contain an email address.
Question edited for FULL 'make model (what it is).
Question moved to 'make model' category.
Duplicate post deleted, two posts made into one. Refresh page to see your question published.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
The CD40 uses MMC and SD cards. MMC cards are a dying breed, so I'd suggest SD cards. You can find those in a variety of sizes at just about any department, electronic, and office supply stores. You can probably find them at drugstores and supermarkets, as well. You can also buy them online.
Be careful to buy SD cards 2GB and smaller, not SDHC cards 4GB and larger. SDHC cards look identical but will not work in the CD40.
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB All other V-Series Cameras: SD memory cards up to 2 GB EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
But try an firmware upgrade.
Why download firmware version 1.07? This firmware version improves memory card compatibility and provides general performance updates. KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
Thanks for the information on the CD40 Digital Camera SD Cards.
That definitely answered my questions and has helped me resolve the issue of not knowing what type of SD Card to purchase.
I will follow your recommendation and purchase the 512mb or 1gb SD Card.
Thanks Again !!!
