The display wont even turn on. Messed around with the STOP button to see if it was stuck. The TV itself turns on fine and a similar treadmill works in the same outlet so its not a power supply issue. Fiddled with all the connections under the hood and made sure they were tight. Couldn't find a reset button anywhere. Any help would be appreciated.
SOURCE: Precor M9.21 Treadmill - Stops under load
This probably did not happened suddenly right? the problem is not the motor however you can easily check the blue capacitor for peace of mind. with the power disconnected, disconnect one side off the capacitor from the top. with a ohm meter put the 2 probes on the cap,you will ear a temporary beep sound from your meter, then reverse your probes on the capacitor and again a temporary sound that mean your capacitor is good and your motor will run OK.
Your problem is more then likely your run belt and bed assembly. When new, these are coated with a wax of some kind for slipping, has you use the machine wax wears off, and so is the belt. You can see a black rubber dust at the rear of the machine. And so resistance increase when pressure is applied on the running belt.
Just behind the on/off switch where the power cord goes in, there is a auto reset 15 amp breaker that trips when too must resistance against the motor increase the amperage over 15amps. At 7 min/m on your speed setting and if the belt is adjusted correctly with nobody on, the motor pull about 6amps, with someone like me 180lbs, the motor pulls an avg of 10amps with a new belt.
If you have a clamp amp meter you can test it yourself.
2 parts you will need to fix this; 50985-101 (bed assembly) and 36355-101 (run belt 17 X 110) This is real easy to install.
make sure these parts are for your machine model # as they did increased the width of their belt over the years
Since 1998 I had to replace these parts 2 times with an average of 3 people using the treadmill every day. This is a good machine and if everything else is good it's worth it. I paid $300 for these parts, i'm sure if you shoppe a little you can do better.
Have a good one
Ben
SOURCE: Precor 9.25i Treamill scrolls message "button is pressed"
Press Enter,speed up and speed down simultaneously. Then enter to view error buffer . press quick start/pacer-stop simultaneously to reset error buffer log. Hope this helps
SOURCE: treadmill get stop with a jrk whn power gets a cut..
Sounds like the wax lubrication has finally boiled off the belt the easiest way eliminate this problem is to rewax the deck. You may purchase this @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Now the fun part to apply this product you must first get the treadmill and walk on it for about 5min to heat up the deck, then stop the unit with your product go to upper third of the belt lift edge of the belt stick the nozzle between the belt and deck squeeze the bottle approx. amount 1 tbs of wax to the center then get back on the treadmill and walk for 10 min this is to heat up the wax so that belt will act like a wick to absorb wax! This should be done every 3 months or so. Their a catch if this does fix the problem you may be investing in a new belt and possible and new deck. Hope this take of it!!
SOURCE: Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
SOURCE: new free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Hi
Looseness or discolorations of the prongs on the plug or the terminals in the wall or extension indicate a weak connection. A weak connection lowers the voltage to the treadmill and causes the motor to work harder. With low voltage the motor draws more amperage and causes the circuit breaker in the treadmill to trip.
Another cause for circuit breakers to trip is the belt needs lubrication. Check for belt lubrication and ease of movement. To test the walking belt lubrication, do not turn the treadmill motor on. Set the elevation to the highest level. Stand near the front of the walking belt. Push yourself firmly toward the rear of the treadmill. If the belt is properly lubricated the belt will take you to the rear edge of the treadmill and dump you off on the floor. If you move and stop, the belt needs lubricating.
Also check this related link:-
http://www.livestrong.com/article/404896-my-proform-treadmill-wont-start/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
