Im in canada and i got american netflix through changing my dns. All of a sudden, it stopped streaming. Any suggestions? (Sorry for the white noise in the background)
My suggestion is download a vpn and make sure you would be using an U.S server. Probably netflix still detected the connection from Canada. A vpn should cover that.
SOURCE: dns error for ps3
O.K. I had just had that little problem out of nowhere 2 days ago! First off Reboot the Modem, then the Router. When they are done turn on the PS3. In the PS3 Menu go to the 2nd Row from the Left and Down to Network Settings. Choose your setup Wired or Wireless. Choose DHCP and AUTO all the way through. If you are Wireless you will need your CODE! When done wait a minute then run the Network test right below in the Menu. You should be Good! This should reset your Network Automatically!
SOURCE: using bluetooth audio with ps3 netflix
The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
SOURCE: Do i contact you for ps3 streaming with netflix or
you need a disc that they provide:
http://www.netflix.com/NRD/PS3
Thank you and enjoy,
Lee
SOURCE: My PS3 blue ray player won't play and games will
possible bad optical laser , try with a disc cleaner and see if help
SOURCE: when i turn on my ps3 red screen apper and said
I can confidently say your ps3 is about to go YLOD, nothing really that you can do about it, if you wanna continue to use it you will have to do a reflow with a heat gun which is a very delicate process, I would advice you to sell it after doing the reflow and let the person buying know about the impending problem since it is a recurring one, go on youtube and search for "Gilksy ps3 reflow", Hope this helps
