Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Your Titan Advantage 400 needs to have its piston seals replaced which is why it is leaking into the oil cup. They are self-adjusting static packings. This is a classic airless wear situation; paint is abrasive. Its easy to do it yourself and if you do, you need to examine the piston; if it is worn or scored it must also be replaced otherwise it will wear out the new packings fast. All the parts to repack it can be purchased in a kit.
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
fill the engine oil tank with 3 quarts of new oil start engine and run at least 30 seconds to allow oil system to fill. verify that oil is returning to the tank by observing through the filler neck. verify correct oil level at the tank adjusting as necessary.
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
