The motorized volume control on my NAD C340 integrated amp stopped working. After reading some advice here, I checked the connection inside from the main circuit board to the small board containing motorized volume and tone controls. I played with the 6 wire ribbon connection a bit and the motorized volume started to work but I lost the left channel. The 6 wire ribbon seems to have bare wires that push into a socket on the main board. How do I remove the ribbon from this socket to clean the bare ends to get a better connection?
SOURCE: NAD C340 has lost ability to switch between inputs
I have the same problem which started about a month ago and seems to be getting worse. I also noticed today, that 1 channel is significantly louder than the other - fault in the pre-amp stage, as feeding the power stage directly gives balanced, albeit extremely loud sound! Looking on eBay, I found someone else selling an amp with both problems. It would nice to think that NAD would acknowledge a design flaw, and fix for free, but my amp is 5 year old.
SOURCE: what is the maximum speaker wattage for a NAD c340
The specs say 2x50W into 8 ohms. I could not located the 4 ohm specs, but it is logical to assume that you can run 2x100W into 4 ohms.
The back panel seems to imply that 4 ohms is a limit for speakers.
So any speaker over 100W capability should be fine, either 4 ohms or 8 ohms.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
It sounds like you're guessing.
Have you looked at the manual?
Register and download the manual for free at
retrevo.com494 views
