Washer will not drain
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
I was having the dreaded “LD” error with my Whirlpool Cabrio (WTW6200S) and could not figure out on my own what the problem was. While searching from forum to forum I came away with a procedure for re-calibrating the pressure transducer in the washer and this solved the problem for me. I’ll list links to where I found the answers and the procedures below.
To do this you’ll need to run Test #6 of the troubleshooting tests; but you’ll first need to place the machine in Manual Diagnostic Test Mode.
Activation of Manual Diagnostic Test Mode: (I only went as far as step 5)
Step 1. Turn machine off, leave plugged in
Step 2. Hold any button, (other than power, cancel or start) for 3 secs, release, hold 3 secs, release, hold 3 secs, release.
Step 3. 88 will flash and press the same button again within 5 secs or the machine will go into automatic test mode.
Step 4. Once you press the button a 2 digit console code will appear for 3 secs.
Step 5. If done correctly the display will read 00 and the add a garment indicator will flash indicating you are in manual mode. In manual mode the lid will not lock, so you can open the lid to verify the water from the valves.
Step 6. Fresh water valve test- Turn selector to Whites, push start, and select temp. Water should come out in the middle. Press start to stop the water.
Step 7. Detergent valve test- Turn selector to Heavy Duty, push start, and select temp. Water should go into the detergent fill cup. Press start to stop the water.
Step 8. Fabric Softener valve test- Turn selector to Normal, push start, and select temp. Water should go into the Fabric softener fill cup. Press start to stop the water.
Step 9. Bleach valve test- Turn selector to casual (perma press), push start, and select temp. Water should go into the Bleach fill cup. Press start to stop the water.
Linkhttp://ths.gardenweb.com/forums/load/lau...
Troubleshooting Tests: (I began at step 7)
This test checks the water level sensing components, and calibrates the pressure sensor.
1. Unplug washer or disconnect power.
2. Access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Check hose connection between the pressure transducer on the machine/motor control and the pressure dome attached to the tub. Check to ensure hose
is routed correctly in the lower cabinet and not pinched or crimped by the back panel.
4. Plug in washer or reconnect power.
5. Drain the tub until all water has been removed from tub.
6. Remove all clothes from the machine.
7. Calibrate the pressure transducer: See Activation of Manual Diagnostic Test Mode, and perform steps 1 and 2 until the display shows 00 and the Add
A Garment indicator LED is flashing. Press and hold the Cycle Signal button until a single beep sounds, and the display shows Pt to indicate zero calibration
has completed. Exit Diagnostic: Manual by pressing STOP or POWER.
8. Select POWER • wash cycle NORMAL • START.
9. Verify that the tub fills to the top of the impeller plate (impeller models), or to a level above the agitator vanes (agitator models), but much lower than the SUPER Load Size water level. If the water level does not fill to this level, replace the machine/motor control assembly. See Accessing & Removing
Link http://www.advantagesupplyfl.com/Whirlpo...
Once I completed the recalibration procedure, and machine worked just as it should. I’ll keep an eye on it, but so far so good. Hope this helps, good luck!
We followed kurticusgt's instructions & it fixed our problem! Thank you, this easy fix probably saved us at least $400 in unnecessary service calls & parts. We also got the LD error & the machine would not complete any cycle past rinse or drain. We ran diagnostics, and the water drained just fine, so we figured the pump was ok, and that the sensor was the problem. After recalibration, the machine now works as it should. And no need to take the machine apart. Thank you!
I just bought this washer alomst 5 months ago. I do a lot of laundry in it. I really like it but about a month ago it started giving me that LD code. I did not get a manual with it but it is brand new. From what I am reading it is a clogging problem more than likely. I will see what they tell me when it comes back from the shop. My question is there a way to help prevent this clogging? Does the monthly bleach cycle(which I hate to say that I have been to busy to remember to do) that you are supposed to do help with this?
Does the monthly bleach cleaning cycle help prevent this clogging. I have the same problem & it is at the shop now & luckily I do not have to pay for the repair as of yet but will have to when it is paid off.
Does the monthly cleaning cycle help keep it unclogged?
same issue,won't drain,spin,etc...LD code. Had the same problem a couple months ago,cost $60 to have a guy repair it. Said it was something in the pump impeller.Probably the same thing this time. I think I could fix it myself,but I just had back surgery and my husband is out of town.So I'll pay another $60!!! Any way this could be prevented? I'm only washing personal laundry with it! Thanks Taunya
code f53 code on whirlpool cabrio washer
