Hey. I have a JVC GR-270U and wanted to download my video to my pc. Connected the camera via 1394 cable. Computer recognizes the camera, but the camera only shows a blue screen. I shows that it is playing and can fast forward, rewind, but now video...just a blue screen. Took it for repair at authorized JVC dealer...said he got it working fine...came home tried to play and connect to computer using DV cable and blue screen again...Please help me.
Thanks!
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
you need an iLink cable. Also known as a mini-i400 or Firewire Mini. If you have standard 6-pin Firewire (IEEE1394) on your PC, you can get a converter cable which is i400 one end, 1394 the other.
Please use the CD which came with your JVC and install the drivers first, then connect your JVC GR-X5 Mini DV. If you do not install the drivers, your PC will never see it.
If you do not have the CD go to the JVC web site and download the drivers and install it. here is the link to JVC web Site http://camcorder.jvc.com/index.jsp
you can purchase a pci firewire card and install to your computer. Or if you video card supports an Svideo connection you could connect via an Svideo cable.
if you are using a desktop, you require a an addon card called IEEE 1394 firewire card, which you have to install it on your motherboard's PCI slot, then using the firewire cable which you get along with the card should be connected to the card and DV port of the camera, then using the MOVIE MAKER software of windows XP, you can download the video.
Since videos are taped in DV format, you need a firewire card (IEEE-1394) and cable. These are cheap. May be your PC already has a firewire card. Just check. Windows XP recognises automatically the camcorder. Moreover, its integrated video capture/editing module, Windows Movie Maker, is very userfriendly.
USB connection is only good for downloading still images (photos) to your PC. For more information, go to http://www.videohelp.com/.
good luck
It uses the mini DV tapes.
