Pls tell in which way you are using A4 papers. Landscape or Portrait.? More help contact me on [email protected]
SOURCE: Ricoh SPC400DN Getting frequent "Press A
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Testimonial: "Springs on left arm are attached. I adjusted plate pressure to Thick and problem seems to have gone away (paper if 20lb, so either setting was ok)"
