Need help with codes for a sansui tv
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
SOURCE: Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
try these codes 0000, 1479, 0479 - from our control booklet
SOURCE: need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
SOURCE: URC-3021 Remote Control: need code on a sansui tv with the one for all remo...
I can help you with your URC-3021 Universal Remote Control issues.
The
codes for Sansui TVs is: 0463.
For complete
instructions on entering the URC-3021 remote codes, please refer to my
posted Fixya Tip One For All URC-3021
Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Code Search
