1. Menu pops up automatically. 2. View switchs to Video 2, Video 1(modes for vcd,dvd). 3. Remote control stops working. 4. Buttons on Tv console stop working at the same time.
if there is something i can do myself please advice. Otherwise i'll contact the service centre.
0039.0033. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
There
are three ways you can connect a DVD player to a TV. Component video
gives the best picture quality, but requires 3 cables for the video
signal alone. S-video needs only 1 cable but it isn’t as good as
component video. Composite video is the easiest connection to make, but
gives the lowest picture quality.
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
From the manual (search Google for CM27101S):
Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve
connected another component to your TV(such as a VCR) using the Video/Audio input, you will
want to be able to view the signal from the component.
To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows:
1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear.
2 Use the WCHVbuttons to select ? Input ?.
3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?.
4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
