Televison & Video Logo
Posted on Mar 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shadows/ghosting is present on screen at all times
Lately, the image is being distorted by shadows/ghosting present on screen at all times. The TV is 3 years old. What could be the problem?
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Mar 20, 2009
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564413
Points
12312
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Toshiba Flat Screen TV Model TZ61V61 Serial #23960912 problem with wiggles and shadows in the corners
Could be video card or screen its self. Does it start out with distortion as soon as tv is turned on or does it distort as it warms up?
3D image, ghost image, with shadows. how can I fix it?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
2helpful
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
2helpful
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Ghosts or shadows around images
I always start my Hitachi research at their website.........
www.HitachiServiceUSA.com...................T.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
