i cannot switch on y mobile bluetooth whe i try to turn on its says bluetooth failed what can i do ??i cannot switch on y mobile bluetooth whe i try to turn on its says bluetooth failed what can i do ??
You can't post conmments that contain an email address.
Hello! Welcome to FixYa! To activate the GPRS settings on your handset, Write GPRSACT in write new message and send it to 511. You will receive the settings of GPRS, Save this settings. There is no service charges to activate GPRS. If you face any problem in sending the sms then there is another solution you just have to call on helpline no of AIRTEL and demand GPRS settings by the AIRTEL service providers, Give information to them about your handset which you are using they will send you the settings of GPRS according to your handset. Save those settings and enjoy GPRS on your SAMSUNG SGH-F480. Fell free to ask me if you have any more confusion, I am here to help. I hope this solution helps you Thank you for using FixYa!
The SGH-F480 will indicate if the alarm is on or off by the Bell Symbol which appears on the top right hand side of the screen. The on or off function will automatically default to the on setting.
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
1. In idle mode, tap 'Menu' then tap 'Alarms'. 2. Tap the alarm you wish to deactivate. 3. Tap again to enter the alarm settings. 3. Tap 'Alarm activation' to highlight, then tap again to select to 'Off' 4. Tap 'Save'.
