Step one: Remove the old cartridges
1. Press the power button to turn on the product
2. Open the front access door. The carriage moves to the far right side of the product
3. Wait until the carriage is idle and silent, and then lightly press down on the cartridge to release it.
To replace the tri-color cartridge, remove the cartridge from the slot on the left.
To replace the black cartridge, remove the cartridge from the slot on the right.
Pull the cartridge toward you out of its slot.
Step two: Install the new cartridges
1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
2. Gently remove the plastic tape by pulling the pink pull tab
3. Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot. Make sure you push the cartridge in firmly until it snaps into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black cartridge, slide it into the right slot.
4. Close the front access door.
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP
integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901,
92-98....currently offered at Costco or Frys today) or if you buy a
remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP
has a smart chip embedded within the nozzle plate at base of ink cartridge
which counts the drops and then registers as empty).....so you'll just need to
live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and
similar while you are using these types of aftermarket supplies. The first
video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem" etc.) typically indicates the internal micro-electronics
of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire
runs at rear and lower side of the ink cartridge are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on all models which use HP 901 cartridges. Refer to
Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer
Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts -
Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers
Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500
J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care
Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print
of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire
Low Ink Warnings:
HP Officejet J4500
HP
901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
