Estion: "i ran disk utility and everything was cool went then I click re start and the computer won't restart and the pilot light keeps blinking... I cab eject the mac disk still won't start... I put the start up disk back in still won't restart whats up ???"
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
SOURCE: Can't eject Install CD Mac OSX Panther
Hi GInette, sorry to hear you are having problems,
here is how you eject a disk that is stuck in the optical drive of a Mac.
Shut down the Mac.
press the power on button
VERY QUICKLY, press the mouse button, the trackpad button and hold it down firmly until the disk ejects.
This is a built-in hardware command independent of your system and always works when doe right, unless the optical drive is no longer recognized by the Mac or if something is inhibiting it's ejection.
Good luck
