I downloaded the firmware update onto my SD put it in the tablet held down the volume up and power button at the same time and I repeatedly get this screen saying it cannot open temporary recovery log.
The only solution i can find to your problem is to delete the firmware update you've put on your table,you need to wipe the data,just reset it to factory settings,,just hold the back and power key then if you see it light ang the logo just release the power key the back remain,then your on the system mode just select wipe data fastory reset or what ever you want just press up and down volume to select..then press back button to start.....hope it help....
SOURCE: charged sylvania tablet for 24 hours & unplugged it but no power
Many times the cause of this problem is u need a new piece where the charger plugs into the device because it shorts out.
