You may download a copy of the manual at http://service.us.panasonic.com/OPERMANPDF/DMCTZ1-MULTI.PDF
You don't need to use the Panasonic software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
SOURCE: digital camera
You can download the manual from this page:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-TZ1S
SOURCE: PANASONIC LUMIX DMC-TZ1
follow some tips given below:
1.try changing the battery ...
2.just plugin the charger with out battery and then try
3. check whether it is connecting with the pc or not ..
if it is connecting with the pc then there is no firmware problem...
if problem persists then the firmware has got corrupted you must installed with the new firmware
or may be the POWER IC might have gone.....
just contact the nearest service technician......
any doubts reply me
i am always here to assist you
thank you
bye
SOURCE: downloading pics from camera to mac
We had trouble uploading to our mac, especially with videos. A camera store guy suggested using a card reader instead of uploading through the camera -- it's much faster. Hope this helps.
SOURCE: Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
