SOURCE: clothes get caught between the drum and the front
there is suppose to be a felt type piece that goes on the drum to full that gap it may have fell off . its a struggle to put on unless the drum is accessible. you can pop the top of the machine off to get better access.
SOURCE: NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
I have the same dryer doing the same thing. Open the door and take the two screws out and lift the top. Remove the two screws that hold the front on. Remove the front. On mine both the plastic parts that stay on the front when it is removed are cracked and needing replaced. I found over 20 buttons that the dryer had pulled off clothes stuck in the front door. I'm sure if it will be cost effective to buy both these parts or not.
SOURCE: I have a GE DSXH47EG0WW dryer and clothing is
if its in the front of dryer you need the front brg and felt replace and the 4 slides . if in rear of drum replace rear barg and do the front . may also need a belt and idler . dryer sounds like if done a few loads .. hope this helps mm
