The unit lamp warning light is on but there is no visible damage to the lamp. Is there a way to reset the unit to accept the removed bulb as a new bulb? or just to get the unit running again
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
You can reset the lamp in the menu, some lamps will last past the recomended time they are rated for but they will lose brightness.
Unplug it and plug it back in. It will come back on, but you'll still need to replace soon.
Exact same problem. I even bought a new bulb. It lit up for 1 minute then bulb light again.
