Just bought the unit used. Fixed the leaks and ran it with 2 T Shirts on a Super wash. Unit filled with water appeared to wash for a few then drained some water. Now the unit will mix the clothes side to side and stop every 25 seconds. It will then start again mixing the clothes then stops for 5 seconds and goes again. I thought it was off balance so ran a Permeant Press with 0 clothes. Same thing! What is going on? Is this the procedure? This has happened so far on Super Wash and Permanent Press. Thanks you so much for any help!
'Now the unit will mix the clothes side to side and stop every 25 seconds. It will then start again mixing the clothes then stops for 5 seconds and goes again."
This is the usual wash cycle it goes clockwise, then counter clockwise to effectivly agitate the clothes.
Have you contacted Malber USA? 516-294-6660. They were helpful with my problem.
Biker- Thank you very much thus far. The load I did lastnight was 3 T shirts and a pair of shorts. It tumbled for intervals of 20 seconds about. Now with a fuller load. About double that it pauses every 10 seconds. Also I noticed same as drying. Finally I noticed on anything higher then 600 RPMS the machine will shake like CRAZY! On the floor and vibrate most of the condo I live in. Any idea? Optimal settings. Probably will have a few more questions and greatly appreciate your time!!!
I have it on those Magic sliders from home depot as I figured moving it each time would be a breeze. Needless to say they don't work! The spinning I can deal with not a problem. I don't even know where the transport brackets are. The back is just a white cover nothing out of the ordinary. Few other questions then I will let you go....
Can I use liquid bleach? Can't find powder WHITE bleach anywhere.
Can the dryer just be used alone without washing 1st?
Once the wash is done do I need th leave the water on for the drying?
They say to clean the sviwel stick looking drain thing in the bottom right corner of hte machine. When I take it out like 5 gallons of water comes out? I can't do that on my floors?
