Replace the battery, Lowes sells the sealed lead battery's for $14.95. Check in the section they sell 'EXIT' signs the battery number you will be looking for is #30128 made by Utilitech.
Step 1. Unlock the bulb careful not to pull too hard to prevent snapping off the ground wire for the bulb and unplug the 'black' and the 'red' wire from the battery terminals.
Step 2. Locate the 2 screws on the side in the grey area use a P1 Phillips screwdriver a P2 will not fit.
Step 3. Carefully pry the 2 half's apart dont pull too hard but just enough to allow the battery to slide out.
Repeat the process in reverse to install the new battery.
PML 9000 won't charge
